Gas tank removal vintage JD 170
   / Gas tank removal vintage JD 170 #1
Digamex
Baltimore, MD
old JD 170
Does anyone know the easiest method to remove the gas tank in a JD 170? Tank has sludge in it which keeps clogging the fuel line. So far, I've used compressed air to blow back up the line, but it only works for a few weeks and then clogs again. Thanks in advance for any advice you can offer.
   / Gas tank removal vintage JD 170 #2
I'm guessing that you remove the seat assembly and the fender pan. That's how you do a 275. When I needed to clean the tank on a project Yanmar I pulled the tank and pressure washed it. Then splashed in some alcohol and dumped it and let it dry in the sun.
2022 COSEN INTERNATIONAL INC V-1822 BAND SAW (A51248)
2022 COSEN...
2015 Dodge Journey (A51694)
2015 Dodge Journey...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
40' CONTAINER (A51244)
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
