Gas/Oil Ratio
   / Gas/Oil Ratio #1
honda23
St. Louis
n/a
I just bought my first gas chainsaw does anybody know the gas/oil ratio I need to use?
   / Gas/Oil Ratio #3
Look at your owners manual.
If you bought it used, then buy a six pack of 2 stroke oil and mix one can with a gallon of gas.
Use gasoline a notch above the cheapest.
   / Gas/Oil Ratio #4
A standard 2 cycle engine should have a 50:1 mix ratio.
It would be best to check the owner's manual. I had an older chainsaw that required a 16:1 mixture. Most of my recent purchases (chainsaws and brushcutters) require a 50:1 mixture, but one (an inexpensive leaf-blower) requires a 40:1 ratio. You can find "universal" two-stroke oil.
Steve
   / Gas/Oil Ratio #5
Check for the ratio. Use high octane gasoline. And use oil specified for chainsaw use. It will be formulated for the hot conditions.:thumbsup:
   / Gas/Oil Ratio #6
... and don't forget the Stabil (or similar).
   / Gas/Oil Ratio #7
Steve
X'4:thumbsup:
   / Gas/Oil Ratio #8
what make / model of saw and we can look it up for you?
Most modern saws are 40/1 or 50/1 (more environmentally friendly) versus older saws that can be as much as 16/1.
   / Gas/Oil Ratio #9
25/1 will give you no problems and ensures there is enough oil to lubricate the motor , 40/1 or 50/1 might be a wee bit environmentally friendly but when you chuck the equipment away because the motor is NBG that is not environmentally friendly
IMO
   / Gas/Oil Ratio #10
I have never had a problem with 40:1 or 50:1, And I put a lot of hours on.
25:1 is a bit excessive. I have ran that rich before for a really old saw that called for 16:1. I ran some of that in my modern 50:1 saw, and the decrease in power was very noticable as well as the smoke output.
So if you want to spend more on oil, have the saw run worse, AND fog for mosquitoes all in one shot, then sure, go 25:1.
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
Kubota L2501D 25HP Utility Loader Tractor (A50322)
Kubota L2501D 25HP...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
Unused 2025 CFG XZ20R Mini Excavator (A50322)
Unused 2025 CFG...
