Gas meter not working
   / Gas meter not working #1
npalomba
Bronze Member
NW Connecticut
My Gas Meter shows empty, I have a 4300... Full tank, anyone else seen this issue with their tractor?
   / Gas meter not working #2
It happened to me awhile ago. When I refilled it it worked fine. I've heard of others with the same problem too.
How far down did you get before you refilled and it worked?
   / Gas meter not working #4
I DIDN"T. The dang thing left me way out in the field and I had to walk back. After I went out and put a little in and brought it back and filled it it has worked fine. Before though it said I had a quarter tank left when in fact I was empty.
   / Gas meter not working #5
I hate it when that happens!!!!!! "Dang thing anyway"
   / Gas meter not working #6
The meter on my 4300 stays a long time at 1/4 to 1/2 then drops like a rock to the red in 20 minutes of mowing. There is still about two gallons in the tank but the drop to red can sure get your attention. I think I will have the dealer replace the tank unit.
   / Gas meter not working #7
I have a 4400 and the fuel gauge stuck frequently. I looked into the tank and found that the float is on a rather long arm and apparently was getting stuck on something. Took a long screw driver and tried to bend it away from the sides a little and haven't had a problem since.
   / Gas meter not working #8
The float on my 4200 will stick on the bottom,side of tank.I pull er up with an injecter tool,only happens when i run er real low.
I normally don't let mine run below a 1/2 tank, I guess I run it down farther and see if it comes back. If not, 50 hours service is coming quickly
TRUCKING INFO (A50774)
2014 Nissan Frontier Pickup Truck (A50323)
2014 Nissan...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
