Gas leak
   / Gas leak #1
NCMau
NC
MF 202/Ford 8N
Can JB Weld be successfully used to fix a small leak in a gas tank, or is there beside welding, a better product available?
   / Gas leak #2
There are some two part putties that are better, autoparts stores have them. There is a other product that is similar to silicone but drys hard. I forget the name of it but it is in a red & yellow tube in the epoxy area & states gas tanks on it.
Mark
   / Gas leak #3
Mark
SealAll fixed a plastic gas tank on a generator with it!
   / Gas leak #4
Seal-All is good stuff. A plastic tank is tough to fix though. A lot of puttys and sealers don't like to stick to it. Sometimes a soldering iron will melt a crack back together.
   / Gas leak #5
The rubber piece were the cut off goes into the tank was cracked, not the tank! I fixed it for my uncle, he didn't want to spend $25.00 on a piece of rubber & plastic cut off!
   / Gas leak #6
Yes it can, there are different types of JB weld also.
   / Gas leak
Thank you all for the inputs. I'm more educated now!
   / Gas leak #8
Plastic tank or metal? I poked a piece of 1/2in rebar thru my tn75 fuel tank once. I had already replaced the tank before and I didnt like the thoughts of buying yet another. I went to the scrap yard and cut off a piece from a plastic car gas tank. I then took a large soldiering iron and started just heating around the hole until it turned shiny and sticky. I then would push the piece of plastic into the hole with the hot soldering iron. I was able to compeletly seal up the hole. I used the iron just like a acet torch and the extra piece of plastic was my filler rod. It was slow go, but the tank never leaked. Lots of videos on youtube showing plastic welding.
   / Gas leak #9
Id be afraid the gas or fumes would ignite in the tank, a soldering iron and gas fumes don't coincide, not saying it wouldn't work but I wouldn't want to do it, I'd get some jB weld waterweld, it's impervious to gas or diesel and works pretty good, bound to be safer than anything with heat!
RIDGID K-400 POWERED DRAIN CLEANER (A51248)
RIDGID K-400...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
