Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Well, while doing some garage cleaning today, I pulled out a sears 44" trail mower ( 8hp B/S ) that I've had for some time.. though seldom used. I bought it back when I had first bought 3 acers, and got it to go with my riding lawnmower as a way to mow faster. This was before I got a tractor, anbd before we had built a house there. Used it a few times, and pretty much parked it. Got tired of it setting in the garage so I went to sell it last year.. wouldn't start.. carb was gunked up, and float stuck.
It was still under extended warranty.. I took it in, and they put a new carb on.. changed the oil.. etc.. sharpend the blades.. etc. Buyer had already gotten another one by then.. so I brought it home used it once.. drained the gas and put it back up.
Now... 1 year later I pulled it out again.. in prep to sell to a co-worker, and same thing.. would stat on a bit of gas dripped in carb.. then die.
I didn't have a rebuild kit, but figured I'd pull the carb apart anyway.
Man.. what an easy carb to clean and rebuild. Took all of 15 minutes to pull it.. clean, and reinstall. Float needle was 'glued' in place not letting gas inthe bowl.. not to mention a ton of varnish.. from just 1 mowing!
Started on the first crank, and then I added some stabil, and lucas fuel treatment to the gas and let it run a while....
2 points.... Brigs carbs are super easy to rebuild.. and gasoline is garbage!
Soundguy
Soundguy
