gas in oil 625i kawasaki
   / gas in oil 625i kawasaki #1
agensstone
blairstown nj
jd 625i
have 2011 bought new gas in oil. have to change oil at least every 20 hrs. jd tells me i dont get motor hot enough to get ride of gas or burn vapors off . have 200 hrs on machine changed oil 8 times.anyone else have problems?
   / gas in oil 625i kawasaki #2
I have seen this issue mentioned on other forums with the JD 620i model (tractorpoint.com). Not sure if anything changed with the 625i design. Some Kawasaki Mule owners have also complained of gas in the oil too. The general consensus on why this happens has to do with the electronic fuel injection system not having a sophisticated enough efi sensor to lean the fuel mixture before the engine reaches operating temps. Some corrective helpful solutions from owners vary from running hotter rated spark plugs to adjusting the air/fuel mix leaner to blocking the radiator with cardboard in an effort to get the engine to warm up quicker.
   / gas in oil 625i kawasaki #3
:welcome:
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2016 Ram 3500 High Top Service Truck (A52377)
2016 Ram 3500 High...
