Garden tractor confusion
   / Garden tractor confusion #1
OutbackL130
chickamauga
L130, 420
I'm trying to search for a garden tractor like the 318 but will consider other models besides john deere as long as its in the same class. Problem is I dont know how to search for it. If I look up "garden tractor" on craigslist I find 1000 used riding mowers for sale. What are some 318 equivilents from other manufacturers to help in my search?
Whatever happened to this class of garden tractors? Do they still make modern versions of the 318 or did the garden tractor class get taken over by home depot mowers?
   / Garden tractor confusion #2
   / Garden tractor confusion #3
i'd search CL for John Deere Mower, John Deere, Kubota. I really like my kubota mowers and I also own John Deere mowers. I have a 430 John Deere which I think is much heavier duty and 10x the tractor. The LX JDs were mostly kawi engines and decent aswell. LTs were okay, but I didn't like my LT155.
the X series JDs are good machines but pricey.
   / Garden tractor confusion #4
What specifically about the 318 are you looking for feature wise? There are many brands of older heavy duty garden tractors out there that can take a variety of ground engaging attachments, tiller for example, or scraper blades, etc, even loaders though they're hard to find. I can't recall but I think the 318 may have had live hydraulics (outlets to connect hydraulic implements). If live hydraulics are required, that would limit equivalent options. I'm not even sure of any off hand, but I think older Ingersols had optional live hydraulics, maybe some of the older Simplicities - not sure. But, if live hydraulics are not a requirement, then you'd have lots of options like Case/Ingersol, Simplicity, Wheel Horse, older Cub Cadets (when made by IH), older Bolens, and others.
I have had several, and still have a 20 year old, Wheel Horse garden tractor. They are heavily built, most with Kohler engines and some with Onans. Implements are plentiful and cheap, relatively speaking, including snowplows, snow blowers, tillers, mower decks, etc., and they are very interchangeable over the years. One thing about Deere is that you will need to find implements more specifically for the 318 or any other models. Deere often changed the design and hook up of implements over the years as they changed tractor models. Let us know more specifically what about the 318 you're looking for.
   / Garden tractor confusion #5
What is your budget?
Why a 318 ('83-'92)?
The only desirable traits of the 318 are power steering and second remote hydraulics. It is a tweener, situated between an X530 and X700. There are many other garden tractors that are nicer and easier to use than a 318. The deere 425 ('93-'01) is twice the tractor of the 318 for about 50% more money. It sounds like your not stuck on the 318, but if you are stuck in the eighties and under $2K you might consider cub 782, 982, 1872, 2072, deere 322, 420, any ingersoll over 16hp, or simplicity 7790H or it's variants. Your best bet would be the deere 425, 445, or 455. Good luck.
   / Garden tractor confusion #6
Quickest way to tell a garden tractor from a cheaper lawn tractor is the rear wheels will be a bit larger and will have four lug nuts holding the wheels on. Lawn tractors will not have lug nuts
   / Garden tractor confusion #7
xskier you forgot about the 430. 20HP Yanmar diesel, hydraulics, PTO
   / Garden tractor confusion #8
If you find an ad for a tractor and want to know about it's mehanical features you might look it up in the "Lawn Tractor" section at Tratordata.com Here's a link to the data on the 318. TractorData.com John Deere 318 tractor information
NOTE: Please read the disclaimer about data entry mistakes and incomplete information at the bottom of the page with the data.
I want a small tractor with power steering and hydraulics to operate a front end loader. Diff lock and 3 pt hitch would be a plus too.
   / Garden tractor confusion #10
With that list it sounds like your in the market for a SCUT like the BX or Max.
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
