garage subpanel ground question
   / garage subpanel ground question #1
Dutch445
Elite Member
Upstate NY
JD X585
Hi all
about to undertake a patio project in the back yard, sort of between the house and garage.
I want to use power for low voltage landscape lights along and around the new patio, in the
block wall, etc.
the garage has it's own subpanel, fed underground from the main house panel. it's not very
large, maybe room for 10 circuits.
out from the back corner of this garage was an electric outlet on a 4x4 post, weather resistant
with a twist style 3 prong 25 amp receptacle. (maybe for a hot tub??)
i removed this, and inside the garage above where the conduit came out thru the wall
was it's GFCI switch, mounted in a work box with no outlet, just the GFCI switch. I plan
on using this circuit to put an outdoor 120v receptacle to use with the low voltage transformer
for the landscape lighting. this is all the easy part
my question comes after this.
during some light excavation behind the garage (not part of the patio project, but a raised bed
vege garden area) we removed the sod and found a ground rod drove into the ground, with
bare copper wire attached to it. since i found it with my little bucket and didn't notice it right away,
i have no idea if it was still attached to any wires heading into the garage or not, there is no
obvious wire sticking out of the house that i can say used to be attached. it's a short rod,
about 24".
the question is could this GFCI circuit have needed it's own ground? or could it be ground for
the subpanel, which is near the front of the garage and this ground was out back?
the inside of the garage is finished with steel siding, and insulated, so it's not as easy as
following wires, they are all buried within the walls.
   / garage subpanel ground question #2
Only a guess, it was a receptacle and ground for a portable generator probably used to back feed that 10 circuit panel in the garage and hence into the house.
spoke with a customer who's an electrician this morning,
he felt it could have been from a hot tub from 10 years ago, things
are different now, but it's too small a wire to be grounding that sub panel.
thanks
i'll use that circuit for an outdoor outlet to power low voltage landscape lights!
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
(4) GOODYEAR WRANGLER 275/55R20 TIRES (A54757)
(4) GOODYEAR...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
