Gannon box question
/ Gannon box question #1
valley
Platinum Member
mountain valley near Tahoe
Michigan 55A, Foton 254
Greetings, I have a question about a Gannon. Can the box be tilted for leveling a field or lot? Thanks
Richard
/ Gannon box question #2
Yes, the 3 point linkage should be adjustable so that the left or right sides can be raised and or lowered. Normally the adjustable linkage is on the right side of your 3 pt.
Hope that this helps you, good luck.
/ Gannon box question #3
Tilting is a function of the three-point hitch not the implement, but Gannon does make a hydraulic tilting grader blade.
Thanks for the discription of Gannon and three point. I have a heap of rocks here but a gannon should work for some of what I have to do. Thanks again!
Richard
/ Gannon box question #7
Many tractors have the adjustable links on both sides, my Mahindra 7520 came that way. I was just stating what is normally the minimum supplied.
2021 CATERPILLAR D3 CRAWLER DOZER (A62129)
2021 CATERPILLAR...
Chevrolet Tailgate Themed Wall Decoration (A61569)
Chevrolet Tailgate...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
2015 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2015 FREIGHTLINER...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
