Gallagher post hole
   / Gallagher post hole #1
yozza
perth w australia
foton 404 europard
Hi folks
We have a 3pl gallagher post hole auger attachment, we have just replaced the seals and bearings, the oil filler is on the under side when operational ,how much oil should go into the unit? we have put 3 litres in. It was interesting that the castings inside were MOWOG which im told is (morris wolsley mg) BRITISH diff parts, the seals were cheap but the bearings very dear and the box looks like it came from the heyday of british car manufacture.
regards Yozza
   / Gallagher post hole #2
Hi folks
regards Yozza
Hi Yozza,
I have an old Gallagher PHD as well (not sure of the year or model number, but the main casting numbers are D79F and D80F with "Gallagher Engineering Ltd" identified as well). It seems you recently had success changing the seals and bearings. Do you have a list of the correct bearings and seals please? I am located in Porongurup WA and will probably get the parts from a supplier in Perth. Many thanks. IBL
Hi ibl and fellow Sandgroper it was a while ago and the unit is still with us it works fine and doesnt leak , my son in law did the repair and i will need to ask him regards where the parts came from he is in the motor trade . i used the machine down your way at my cousins vineyard in Frankland last year probably needs a smaller augar attachment as the large one is a bit worn and didnt like the hard ground much although we did add some more cutting teeth but havent tried it with the new dentures. PM me if you want and we can keep in contact
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2018 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2018 Ford F-450...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
