Gained 6 HP on the dyno
   / Gained 6 HP on the dyno #1
cantbeatadeere
Bronze Member
UPSTATE new york
If you saw my post of my recently purchased 2520's three point dropping to the floor in a short time, having trouble idling with the three point up at all due to a continuous "load" on the motor due a piece of metal trapped in a hydraulic valve. well I put it on the dyno a while back and I was only getting 51 H.P. at PTO speed, I checked and adj. timing, carb. settings, made sure the choke was opening all the way, air filter was good, governor settings spot on, anyway I was a little baffled on the lack of power from a low hr. perfect sounding/running machine. After fixing the three point, the motor runs so much free'r I thought I would throw it on the dyno again----low and behold 57-58 H.P at pto speed and will pull a max of 62 at approx. 420 rpm on the pto .....much better and about par for Deere's specs(which are usually quit accurate). I will try and post a video of some dyno runs later in the week....pics and vids are always nice!!
   / Gained 6 HP on the dyno #2
Good to hear about the improvement.
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
WB Mower (A50120)
WB Mower (A50120)
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
2020 Can-Am Ryker Rally 900 Ace 3-Wheeled Motorcycle (A51694)
2020 Can-Am Ryker...
