G2160 questions
   / G2160 questions #1
LR, AR
Several.......
New guy here...not new to Kubota (I work on them occasionally at my job) but I've had zero experience with the G2160 with the RCK48R rear discharge deck (direct shoot).
I bought this thing used. WELL used. I have it running and it mows again but my problem is that the grass clumps up severely. It will plug the discharge, then I have to manually clear it with the lever on the front of the bag assembly. Tonight I took the bag off and then tried to mow without the bagger, just leaving the rear of the assembly "open" so that grass would discharge out on the ground rather than into the bagger. It still plugs. Right in the back of the chute, there is a plate that lifts when the lever is moved. That plate is curved in an "s" shape. Right at the rearmost curve, where it's curved upward, the grass builds up and then of course plugs or falls out onto the ground. I love this little mower but I absolutely hate the deck and bagger. I have a country yard and have no idea what to do with the clippings when I'm bagging. In the fall, I can see the bag being handy for moving pine needles and leaves, but in the spring/summer, it's worthless. I'd just as soon put a 54" side discharge on it if anyone's got one, that or continue to use rear discharge if anyone has any suggestions on how to make it quit plugging up?
Does anyone have a picture of up inside the chute, looking down toward the deck? That might help me understand what is missing from this mower, if anything.
   / G2160 questions #2
As for the mower ,its a great unit .As for cutting in damp conditions ,it sux!! On mine I took the lower plate off the cleanout. And I took an old traffic sign and bent it at an angle and left it loose.Kubota has a rear chute but it is 130.00 bucks and I seen it as an unnecessary expense for the rear discharge.And a 30 amp fuse on the saftey switch was used to bypass it.
   / G2160 questions
Ok...was looking at the diagrams and I am missing the rotator plate. Based on what I can see in the diagram, it appears that the plate goes up under the discharge of the mower and extends back toward the tractor's chute. I don't have any of that rotator plate stuff.
Does anyone have any of that? The linkage and all...or even just the rotator plate itself will do for right now. That or a 54" side discharge deck, I'd trade or buy one (RCK54-G21 or RCK54-G24)
INOP/NON-RUNNING 2007 Peterbilt 378 Flatbed Mud Mixer Truck, VIN # 1XPFDT9X37D666626 (A51572)
INOP/NON-RUNNING...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2010 Ford F-150 4x4 Pickup Truck (A51692)
2010 Ford F-150...
UNUSED AGT 46" EXCAVATOR HYD BRUSH FLAIL MOWER (A51248)
UNUSED AGT 46"...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
