Oil & Fuel G214 maintnence help
   / G214 maintnence help #1
WKTEDDYBEAR
east of Seattle,Wa
Farmall SuperA
am trying to due some needed maintenance on an elderly friends tractor that I use to mow her fields.
book says use 80wt oil in transmission seeing else where use hydraulic fluid which is correct? I assume the little dipstick near rubber plug is to check level of transmission and also assume that transmission lube and hydraulics use the same fluid?
Where do you check rear axle/differential fluid, or is it also tied into transmission fluid?
have couple filters, I think 1 goes underneath off the side of transmission it is metal mesh believe #1480-508-214-00
other is paper #1524-102-311-00 have not figured out what it is for, ideas?
this is a whole different world then my SuperA,LOL
take care and have a great one!
Paul
2015 PETERBILT 389 (A52472)
2015 PETERBILT 389...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
Chery 7' 20 Drawer Workbench (A50121)
Chery 7' 20 Drawer...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
