G1900S intermittent starting
/ G1900S intermittent starting #1
txcactusdude
I have a G1900S that will not start intermittently. Today after mowing for about 2 hours I stopped the tractor. I blew it off with the leaf blower to get the grass and dust off. When I went to put it back in the shed it would not start. This same thing happened a couple of weeks ago.
The Stop Solenoid was oscillating open and closed when I went to start the unit and it would not fire. After trying several times I jumped the unit off my car and it fired right up. I tried a couple of more times on the tractor battery and no problems. I just put a new battery in within the last month.
Obviously I have some electrical gremlins. Any advise on where to start looking? How do I check the dynamo to see if it is still charging the battery properly?
Thanks,
Dennis
/ G1900S intermittent starting #2
A 12 volt battery fully charged will have 12.6 volts-2.1 volts per cell.A voltmeter is neded to check the charging voltage of the dynamo-should be about 14 volts.First guess,you have a connection problem somewhere-Good Luck!
2018 Toyota C-HR Hatchback (A59231)
2018 Toyota C-HR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
1992 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1992 AM General...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A59230)
2007 Oshkosh...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
