G1800S rear wheel interferes contacts rear gauge wheel on hard right turn
   / G1800S rear wheel interferes contacts rear gauge wheel on hard right turn #1
kb5won
Princeton, Texas (DFW)
BX25, TG1860, G1800S
My 4-wheel-steer G1800S seems to have a setup issue. On hard right turns, the right rear wheel rubs on the right rear deck wheel. I don't have an owner's manual for it yet (on order), so I'm wondering if there is a setup procedure for the deck? I was thinking about trying to shorten the front link some, but it looks like it is already adjusted about as short as it can go.
It only rubs when the deck is down, no interference issue with the deck is raised up.
The rear axle is bolted to the frame, I don't see any adjustment potential there, so I'm thinking the only adjustments I can make are in the deck.
Any wisdom here? Does the owner's manual cover how to set it up correctly?
UPDATE: I wound up cutting the right deck wheel bracket up and fabbing a dogleg to push the wheel out by 1-1/2". That seems to have fixed the interference issue. I started to buy a new bracket because I suspected I had the wrong one, but Kubota has obsoleted that part.
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
