G1800/G1900 -- how do you disengage the HST to tow it? Or, can you?
   / G1800/G1900 -- how do you disengage the HST to tow it? Or, can you? #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
The electric fuel pump on my G1800S died in the middle of my yard today. How does Kubota expect you to move these things when they're dead?
I ended up using the B7100's three point hitch, buy connecting my trailer-towing adapter via a ball-mount with the ball removed with a large pin to the towing tongue and lifting the back end up with the three-point hitch, and towing it backwards with the back end up the air. I'm sure the neighbors were impressed.
Anyway, there is a label on the thing warning, "Do not tow, damage will occur to the transmission".
Any recommendations on an inexpensive source of a new fuel pump?
jas67
   / G1800/G1900 -- how do you disengage the HST to tow it? Or, can you? #2
I have the TG1860, on the right of the hydro there is a lever, push it forward to disengage.
   / G1800/G1900 -- how do you disengage the HST to tow it? Or, can you? #3
Have a G2160 and there is no release valve and you cannot tow it.
David Kb7uns
I called Messick's on Monday, and had the replacement fuel pump yesterday. It is back on, along with a new fuel filter, and I'm back up and running. I didn't even have to bleed out the injectors, it ran rough for a minute or so, then smoothed right out!
SICKER ROD W/PIPE RACKS (A48992)
SICKER ROD W/PIPE...
Wolverine GB-11-72W Skid Steer Grapple Bucket (A47371)
Wolverine...
2016 Ford Taurus AWD Sedan (A48082)
2016 Ford Taurus...
Bush Hog Model 2010 Rotary Cutter (A49251)
Bush Hog Model...
John Bean Sprayer Tank with Agitator (A47371)
John Bean Sprayer...
2014 Big Tex 12ft. S/A Utility Trailer (A48082)
2014 Big Tex 12ft...
