G1800 fuel and temperature gauge problems
   / G1800 fuel and temperature gauge problems #1
Texwing
Bronze Member
HST3710, FZ2100
This post is to assist others that are having problems with G1800 temperature and/or fuel gauges that will not work, or work intermittently. While electrical problems are usually suspected, it has been noted on my unit and others (Phil) that the needles of these gauges are actually getting stuck to the posts, and the solution is to dismantle the instrument panel and correct the problem.
Still, certain electrical problems can cause these same issues, and after reviewing the schematics that "Jinman" was kind enough to forward, I think a couple of easy "checks" can be made to rule out electrical problems.
I am no expert on this subject, and would invite other forum members to weigh in on my logic if any part looks incorrect or needs clarification.
Each of the gauges has three wires attached; two are common to both gauges.
The third wire from each is unique to that gauge and goes to either the temperature sending unit or fuel sending unit, where resistance is measured.
12volt DC + leg to gauges: if the "oil" (and glow plug) light is still working when the key is turned to the on position, then the gauges will be getting power, so you can rule that out as a problem.
12volt DC - ground leg to gauges: If the two instrument panel bulbs still work that light the panel (sorry, I do not remember if the headlights have to be turned on, but try it both ways) then your gauges should still have this shared ground leg, and so ground or common to the gauges should not be the problem.
Wires to sending units: If it appears you have both 12volts + and - from the above checks, then with the key on, momentarily remove the wire from each sending unit and touch to ground, to see if the gauge reacts; if it does you could have sending unit issues.
If you get no reaction from grounding the sending unit wire, then there is an excellent chance your gauge needles are simply stuck to the posts, so you may wish to proceed to dismantle the instrument panel and correct that problem.
   / G1800 fuel and temperature gauge problems #2
Texwing, thanks for the tips , Will try tomorrow,,,Sam
Hi, let us know what you find, and I wanted to add on the problems with the instrument needles sticking to the posts, that the needles and post (on mine, anyway) looked clean and new, not crusty or decomposed in any way, which is why i did not think that could be the problem, but it was.
   / G1800 fuel and temperature gauge problems #4
Texwing, Will keep you posted, thanks ,,,Sam
   / G1800 fuel and temperature gauge problems #5
Well, sorry for dragging up an old post, but it was invaluable to me. I'd have never thought "needles sticking" to the cold rest post was ever an issue. I recently bought a G1800S and the temp gauge wasn't working. after some electrical checks...which all checked out ok (even the buzzer worked when I grounded the temp sensor), i came across this post..needle on cold rest post..hmm...ok...well..that's exactly what it was..i went the hack route...instead of dismantling the instrument panel which kinda looked like a pita (steering wheel, throttle lever..electrics...other stuff..) i just drilled a small hole in the plastic cover from the top and fished a wire in there and pushed the needle off the post...and ...hot ****...gauge works perfect now!!
I covered my small hole with a tiny piece of clear packing tape...can't even tell it's there..and if it sticks again I have easy access.
   / G1800 fuel and temperature gauge problems #6
Hi-ho Kubota owners! I just found this post! Thank goodness!
After a couple of years with my G1900 having nonfunctional temp and fuel gauges, I did take the dash apart and, lo & behold, *both* gauge needles were stuck to their posts!
I unstuck them, but only the fuel gage came back to life, so...
50% fixed!
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2021 Dosko 337S-13HC Walk-Behind Stump Grinder (A49461)
2021 Dosko...
2010 Cat CM1210106 Rough Terrain Forklift (A51242)
2010 Cat CM1210106...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
