g1800 dash removal tech
   / g1800 dash removal tech #1
chevytex
kubota g1800
Quick question I hope , Following the threads for gauge and light problems on the g1800, I am in the process of removing the gauge cluster to get to the gauges to chech voltages and remove the clear gauge lens, I got the steering wheel off fine , but the throttle lever arm on the left side is stuck on , pulled the cotter key that holds the arm to the inside of the shaft, looks clean but maybe surface rust inside the mating surfaces , Any words of wisdom for getting the arm out of the shaft, , thanks ,,,,Sam
kubotafan, thanks for the tip, have been hitting it with penetration fluid now, will give it a tap ot two today , thanks ,,,Sam
   / g1800 dash removal tech #3
I had to take mine off this morning and it was a bugger,, :( The throttle cable broke under the dash,, I could get the dash part way up but couldn't reconnect the cable with it still in place,, I ended up beating mine off...:mad: Then I had to file it a lot to get it to go in and out smoothly..
I can tell you one thing NOT to do,, don't use heat,,, I melted the upper plastic bushing and hmmm now the lights won't work,, :confused2:..
But it's all back together and works fine now,, 4 hours later ..
hr3, Man sounds like it put you thru the wringer, I received my workshop manual today after lunch , I guess I will read that section on the dash removal closely. thanks for the warning,,,,Sam
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
378807 (A51572)
378807 (A51572)
