Just acquired a G1800 with 48" mower deck. The center blade cuts lower than the outer two blades. I measured the blade height under the deck and the center blade is 5/8" lower than the outer blades. It does not appear to be installed incorrectly. The mower deck is way out of whack adjustment wise, and I've been tinkering with that. But with the deck on the ground, center is clearly lower. Any thoughts on way? The blade does not appear to be bent. Thanks!
