G154 PTO Seal, and Draw Bar
   / G154 PTO Seal, and Draw Bar #1
NHmitch
Platinum Member
SW New Hampshire
Bolens G154/IsekiTX1300F
Hi Guys,
I just had a quick question if anyone has had experience changing their PTO seal. I bought a new seal, and I would like to replace the old one, because I plan on using the PTO a lot more. How complicated is this job, and do you have to drain oil? Also, as you can see, the draw bar attachment below the PTO is orange. Is this the factory draw bar receiver, or was this added. I wonder if it came off of a Kubota, based on the color. I need to find a draw bar that will fit in it,because for certain jobs, it is safer than towing with the 3 point draw bar. Also do they make a cover that will fit over the PTO shaft like you can put over the ball hitch on your truck to help keep it less funktified, if that is a real word? Thanks for the help!
   / G154 PTO Seal, and Draw Bar #2
You have to remove the rear cover to replace the seal. You will probably have to drain some oil from the rearend. The OEM hitch is a flat piece of metal bolted to the rear end housing. Don't know of a cover.
New Land Hero Mini Excavator (A53002)
New Land Hero Mini...
Bad Boy 747cc Outlaw **Does Not Run** (A50121)
Bad Boy 747cc...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
2015 Peterbilt 320 Heil Front Loader Garbage Truck (A50323)
2015 Peterbilt 320...
New Edco Hand 12" Post Hole Digger (A50774)
New Edco Hand 12"...
