G100 Power FLow install question
   / G100 Power FLow install question #1
kjms8968
Hi All,
I purchased a new power flow adapter from my JD dealer and foolishly decided to install it myself. Needlesstosay, it's been one headache after another. I am in the final stages on installation and ran into a SNAFU. I was hoping someone could guide me on this one.
Here is the install guide on-line:
OMM149858_I3
I am in this section:
Installing POWER FLOW and Belt
and I am on this step:
1. Pull on POWER FLOW belt loop (B) to release tension from POWER FLOW tension mechanism (C). Lever (D) must be free to rest on blower housing.
but the tension bar doesn't seem to do anything (swings freely and doesn't seem to be attached to anything). I'm wondering if the unit is broken or missing a part.
any assistance that anyone could offer me (aside from talk to the JD folks -- they've been very little help) would be greatly appreciated.
TIA,
--k
   / G100 Power FLow install question #2
As I continued reading past the part that you quoted, I found a section that said "10. Pull lever (M) to rear to tighten belt."
Might be this the step your lacking for belt tension ?
Hi,
Thanks for the reply. I should have been more clear. The problem starts actually on step 8B.
NOTE: Belt should not be under tension. If tension exists, repeat pulling of belt loop to release tension from POWER FLOW tension mechanism. Lever must be free to rest on blower housing.
The problem is that the belt *is* under tension and we cannot attach it to the second head of the sheave. The tension bar doesn't seem to do anything and there doesn't seem to be any way to release the tension.
Thoughts?
Thanks!
k.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
Charlotte County (A50323)
Charlotte County...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
Electric Mobility Scooter (A51694)
Electric Mobility...
