FYI, 2005 Cub transaxles...
   / FYI, 2005 Cub transaxles... #1
JTKub
Veteran Member
West Falls, NY
TYM T224
It looks like the hydrostatic drive portion of the new cub 2000/2500 series is made by hydro-gear! The hydro portion is aluminum & bolted to the input side of the iron diff. & has the drive shaft bolted directly to it. The hydro assembly is fairly large, about the size of one of the big coffee cans (40oz??). The cast diff/pumpkin is large too, exterior dimensions remind me of the old school 'deere or IH Cub iron rears, of course, with a little less iron. The diff has a dipstick/fill port out the rear, and a drain hex nut on the bottom. The spin on filter base is machined into the iron diff & is fed from the pump/drive via an external steel tube. The filter is big. OD of a fram PH8A (or equivalent), but shorter. You have to get under the tractor to see the 'hydro-gear' label. I had to put'er up on ramps to see (yeah I know… I need to get a hobby!) If anyone wants the numbers off the tag, I'll crawl back under!
Joel
I picked up a couple of intersting tid-bits. Just couldn't leave well enough alone...I emailed hydro-gear inquiring about what aftermarket oil (viscosity range) they recommend for the new CC 2000/2500 transaxles should you (some day) decide to not use cub cadet brand hydro oil. They got back to me within a couple hours stating that they ship the hydrostatic drive units to CC dry & since the hydro drive and differential share the same fluid, hydro-gear recommends using what CC specs. Come to find out, hydro-gear builds the hydro drive only (p/n BDU-10L-225) and has nothing to do with the new cast iron differential! CC sources out the cast iron diff and does the transaxle assembly themselves!?
G/luck
Joel
   / FYI, 2005 Cub transaxles... #3
If you go on hydro-gear and find out what other are using.I will cutt to the chase I have a 2180 that I use in my lawn business,I use mobil 15w 50 syn in the 2180 cub,Ihave been running 15w50 syn for a good year now.
Cool. That's what I kinda figured. Pretty much all the newer hydro-gear units run on 50wt's
Thanks!
Joel
2019 FREIGHTLINER (A50323)
2019 FREIGHTLINER...
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
2016 COTTRELL EZ5307XL CAR HAULER TRAILER (A52141)
2016 COTTRELL...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
DIRTDOG CBX60 5' BOX BLADE (A51243)
DIRTDOG CBX60 5'...
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
