FX28D Hydraulic flow/ add a backhoe?
   / FX28D Hydraulic flow/ add a backhoe? #1
frankh
Hi all,
I've always had a desire to dig the odd hole/trench and I hate using a shovel!
I have heard several pros/cons to adding a small backhoe attachment to the FX28D and I'm still debating the idea.. What do you think? 3 point OK, or weld up a frame mount?
Seems 'hoes need a fairly healthy (10 to 12 GPM) of pump flow.
What is the flow of the FX28D? It would seem easier to add rear hose connections to the tractor (come off the FEL connections on top of the rear axle), rather than add a PTO pump..
Thoughts?
   / FX28D Hydraulic flow/ add a backhoe? #2
I think your FX28d might put out closer to 7gpm. I think you would need a pto pump.
   / FX28D Hydraulic flow/ add a backhoe? #3
I had two FX42Ds with 3 point backhoes on them, but I was very careful in how I used them.
They had their own pump and hyd tanks. They worked ok for digging holes(carefully)
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
JCB Wheel Loader (RUNS) (A50774)
JCB Wheel Loader...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
