FX24D lift slow going up
   / FX24D lift slow going up #1
jmf7112001
Eastern Ala
Many different models
I changed the Hydraulic filter and cleaned the transmission filter. Still nothing has changed. Adjust the lift control, but that only control going down. I got both manuals on the tractor, but can't find the answer. The only thing I have a question is the Long mesh filter on the right side. When it is removed there is a about half inch hole in the side next to one of the ends. Does it matter which way it goes back in? Anybody got one of these, please contact me.
   / FX24D lift slow going up #2
I couldn't find any other posts from you about this so I think a little more history would be helpful. Did this just start happening, always done this, or bought it that way? Is it just slow but still lifts the implement easily or does it not lift it at all? Do you have a loader on it? What spin on filter did you use? There are several filters being sold that do not allow enough flow.
Do you mean in the screen portion?
Aaron
Parts@HoyeTractor.com
(940)592-0181
Arron thank you for the reply. The spin on filter I got from you #551229. This will lift the box blade fine and lower it good. But the lift takes forever and a day to get up. I just bought it and it seem ok then. Yes it has a loader, but the loader works fine. I believe the long filter on the right side is called the transmission filter. When I removed it I didn't notice the hole I refering to. Only to realize it was on the outside, right end. Should that filter be placed a 12:00 O'clock, 3 - 6 - or 9 O'clock. Or does it make any difference. Help Please.
   / FX24D lift slow going up #4
I pulled one of the screens out of one of our FX24 parts tractors and the screen did not have any holes in the side. Just 1 big hole in each end. I sent you a picture of what it should look like. If the loader works, I would not think that would be the problem though anyway.
I wonder if either the loader could be hooked up wrong or, maybe, they used a hose that was too small or a fitting is restricting some of the flow somewhere. Just a guess.
Aaron
(940)592-0181
378812 (A51573)
378812 (A51573)
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
2015 CHEVROLET SILVERADO 2500HD (A53843)
2015 CHEVROLET...
