FWA vs 4 Wheel drive
   / FWA vs 4 Wheel drive #1
F100Panel
Renss. County NY
Usually something with a Loader
Am looking over for purchase several larger/older ( early 80's) 4x4 Loader/backhoes. Some list as 4x4 others list as FWA/front wheel assist. Is there a difference and what is it?
   / FWA vs 4 Wheel drive #2
</font><font color="blue" class="small">( Is there a difference and what is it? )</font>
Probably no difference. I guess to some, 4 x 4 means all four wheels pulling all the time, while "front wheel assist" or Deere's "mechanical front wheel drive" (MFWD) means you can shift into or out of 4 wheel drive, and of course, unless you have a differential lock on one or both axles, you might say that when it's in 4 wheel drive, it's actually only 2 wheels pulling; one front and one rear since the differential allows one wheel on each axle to slip. And if you have a differential lock just on the rear axle, fairly common I think, then you'd have 3 wheels pulling. Is that confusing enough? /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
   / FWA vs 4 Wheel drive #3
I believe that on older units, when FWA first came out, they were hydraulically vs mechanically driven. Hence the FWA label. Now, it seems, depending on manufacturer, MFWD, FWA, and 4x4 are all used interchangeably, and all mean the same thing.
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Serco 270 Log Loader (A52384)
Serco 270 Log...
2022 Freightliner M2 4 Car Rollback (A53117)
2022 Freightliner...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
