Fuse Panel Sale
   / Fuse Panel Sale #1
Scrambler82
Veteran Member
SoCal
Mahindra Max 28XL, HST, TLB
A few of you and me, are mentioning about adding auxiliary fuse panels on their tractors; they will need to be sealed or classified as Waterproof.
I saw this ad and have used this company before for a large wire purchase so I though I would post it up.
Their prices aren't the lowest but they usually have good products.
Del City has a Mini Fuse Panel Sale.
They state they are sealed so... waterproof, should be the name of the game.
These are IP66 rated when used with cover and can handle over 150 amps total, half on each side of the panel, that should cover most circuit requirements on our tractors.
Sealed Mini Fuse Panels
i hope it helps !
They also carry a lot of other electrical product.
   / Fuse Panel Sale #2
Those are nice looking panels! I was surprised how hard it was to find a decent small panel when wiring up front/rear cams on my Kubota recently. I ended up just using separate fuse holders.
I have used Blue Sea panels in boats for many years, and they would work for a tractor if there was enough room. But I thought they were just going to be too large where I needed to put them on my Kubota.
   / Fuse Panel Sale
Here is a small fuse strip.
Needs a fused power wire and relay if it is controlled by the ignition but nice and small.
It will handle 80 amps, 10 per circuit.
That should be enough for most things we do on our tractors.
The other pnes were 30 per branch but 80 total per side.
   / Fuse Panel Sale #4
I got one from J&N Auto in Columbus Ohio area 10 circuit fuse panel w cover for under 25 bucks, not a bad deal.
<Mark
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
2005 Mack CV713 Granite T/A Roll-Off Truck (A50323)
2005 Mack CV713...
Kubota SVL95-2 High Flow Cab Skid Steer (A52748)
Kubota SVL95-2...
2019 Case-IH 370 Steiger (A50120)
2019 Case-IH 370...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
