Fuse keeps Blowing!!!!
   / Fuse keeps Blowing!!!! #1
ohiocub
When I turn the key to start the fuse blows right at the light position.And when i do get it to start the fuse blows when i turn it off.I put in a new ignition switch hoping that would solve my problem.It didnt. /forums/images/graemlins/confused.gif
   / Fuse keeps Blowing!!!! #2
You must have a short somewhere in the lights or wiring. It might help if we knew what brand/model of tractor you are having this problem on.
Its a cub cadet 2140
   / Fuse keeps Blowing!!!! #4
Over in the ford sub, an owner had that problem and it turned out to be a wire in the wire harness was damaged and shorting to the frame.
Try isolating one wire from that circuit at a time till you find the offender.
Easy way to do it is to disconnect all wires from that line and re-attatch till the fues blows. Could also check each line with an ohm meter or test light.. etc...
Soundguy
Problem Solved Thank You.
Now I Have Another Problem /forums/images/graemlins/mad.gif
   / Fuse keeps Blowing!!!! #6
</font><font color="blue" class="small">( Problem Solved Thank You.
Now I Have Another Problem )</font>
Now that's not fair! You just telling us the problem is solved without saying what you did to repair it? Come on man, tell it all! /forums/images/graemlins/smirk.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif John
   / Fuse keeps Blowing!!!! #7
Right you are: Now he has another problem he wants help with and has not told us yet how he fixed the ist one. I suggest we not respond to his post till he opens up and gives us the repair facts.
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2018 DRAGON 130BBL VACUUM TRAILER (A53843)
2018 DRAGON 130BBL...
2003 500 BBL FRAC TANK (A53843)
2003 500 BBL FRAC...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
MISC WRENCHES (A53843)
