Fuse box on 2010D?
   / Fuse box on 2010D? #1
osumason
Oklahoma
Branson 2400
Could someone please tell me where the fuse box is on the model?
I had to replace the voltage regulator because of a small electrical fire. After replacement all the lights now work, but the fuel and temp gauge still do not work. So I guess I'll check the fuses.
I have the wiring diagram, but still cannot find it.
thanks.
   / Fuse box on 2010D? #2
as you sit in the seat look down to your left and it should be mounted on the rear side of the fuel tank bracket.there should be a small panel w/4 screws.take the panel off and fuse box should be behind it. russ
thank you...right where you described:thumbsup:..blown fuse, problem solved.
   / Fuse box on 2010D? #4
glad to help,good to see you got the problem solved russ
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
2019 CATERPILLAR 279D SKID STEER (A52705)
2019 CATERPILLAR...
2017 Chevrolet Tahoe SUV (A52377)
2017 Chevrolet...
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
