Fuse and wire size
/ Fuse and wire size
So are those LED Lights the ones you are going to use ?
If so, what is the manufacturer's requirements for amperage for each light ?
Do you have a manufacturer for these LEDs ?
Yes, these are the ones I plan to use. They are some cheap-O lights that are probably Chinese and do not list anything other than being 27w. The first four I bought were from Tuff LED, an American company. When I bought the case of ten they were not branded but are the exact same, as far as I can tell.
/ Fuse and wire size #22
It's s lot harder to switch off (i.e. extinguish/break the arc) of DC current than AC current because there is no zero voltage crossing (or zero current crossing) that a 60 hz (sine) wave has every second. That's why the DC rating of a switch is usually lower than its AC rating.
Interesting question as to whether a 27 watt at 12 V light draws less current if the voltage is 14v. Why would the wattage stay constant? It's not like a mechanical load that stays steady.
Not sure about LEDs, but with other lamps one would expect the resistance (R) of the filament to stay constant. We know R=V/I, or I=V/R; and from before power: P=VxI, so substituting V/R for I, P=V^2/R. If R is constant, the power goes up by the square of the increase. So for a 27Watt at 12v lamp, 27W=12^2/R, solving for R= 12V^2/27watts=5.33 ohms.
At 14 volts the power is 14^2/5.33ohms=36.75 watts, which at 14volts is (36.75W/14V=) 2.62 amps.
So.... Question is : are LEDS constant power, or do they get brighter (use more power/watts) when the voltage increases like an incandescent does?
/ Fuse and wire size #23
Another stupid question. Why are switches like this rated for AC when most would be used for DC??
I think what I'll end up doing is installing solenoids near the lights and using the hot wire (hot with key) provided by Kubota for a work light to power the switches. That way I can eliminate the fuses at the switches (except for the power socket), not have to worry about over taxing the switches, only have to run one big hit wire to where the lights are and not have to worry about leaving the lights on when the tractor is off.
Anything wrong with this plan?
There are plenty of DC rated switches, do a search on google.
Yes, you could add a solenoid but I would also leave the fuses attached, as a safety feature.
Unless the "work light" circuit is protected by the same type fuse, don't forget, if you go this route, you will only have "one" fuse protecting your switches now, something to think about.
Heat from excessive current is what you need to worry about on those ac switches.
You should be fine with 2 lights per switch, I personally don't see a need for relays on this set-up,
the load is just not big enough.
/ Fuse and wire size #25
Thanks guys. I have a little bit better understanding now.
The only question I have is about one recommendation of four lights per 15a fuse vs another of 7. Using the provided formula, and the fact that all seem to agree on 2a per light, it seems that 7 lights on each fuse is correct.
Should have mentioned the plan was to run four lights on one switch and two on another. The third would be empty for now.
Seven per fuse is possible, but not recommended. It is advisable (in fact it's a code requirement for building construction) not to run lighting circuits at more than 80% of their rated protection. I calculate a quantity of 5 of your 27-watt lamps will squeak in under 80% of your 15-amp capacity.
xtn
/ Fuse and wire size #26
If you do decide to run five incandescent lights drawing 12 amps on a 15 amp circuit you need to run a relay and at least 14 gauge wire.
Now if you are running LEDs... First you need to determine the actual load, the current requirements. The you can determine the rating of the circuit components.
DO NOT ATTEMPT TO RUN the 12 amps thought a switch and the main power wire needs to be fused as close to the battery as possible.
/ Fuse and wire size #27
On DC circuits do not forget voltage drop. You cannot use the tables set up for house wiring. I do not have the info handy but it is all on the internet. Also your friendly auto supply house can keep you out of trouble. Trailers are especially bad as you have to calculate from the battery to the last device. As the distance goes up the voltage goes down and the amps on that wire/fuse go up. The wire is a big resister in the circuit if not large enough. The weak link may be the contacts in the switches. You did not mention their amp rating.
Ron
It doesn't work that way. The voltage is constant at whatever the charging system is putting out (ideally between 13.8 and 14.2 volts) so increasing the total resistance in the circuit lowers the amperage draw.
/ Fuse and wire size #28
Where did you get that fused switch panel that is very cool.
Amazon. I was looking for just the rubberized switches and came across this panel for about $25. Search for "3 gang switch panel".
/ Fuse and wire size #31
Mace,
You may want to review this some more. Yes, at the battery it will be whatever the Voltage Regulator is set for. 50 feet from the battery; wire size staying the same, you will have less than that voltage, but the lights, winch motor Etc will still try to put out its rated wattage therefore raising the amps till the fuse blows or the wire melts. Thats why the fuse is rated per the wire size; to keep the wire from melting. Set this up on the bench and it will become clear. Note I man deliberately avoiding gett into theory too deep.
Ron
/ Fuse and wire size #32
Mace,
Ron
This is incorrect. Resistive loads such as lights and heaters will draw less amps as the voltage drops. The wattage is not fixed. The only thing fixed in the circuit is the resistance.
Remember E=IR, or solving for I...
I=E/R
R being fixed, its easy to see that as voltage drops current drops too (and wattage).
I would challenge you to set up a light bulb and 2, 6 volt batteries on the bench.
I will bet you next weeks paycheck that the circuit will draw less amps at 6 volts than at 12 volts.
You guys are making my brain hurt.
/ Fuse and wire size #34
Just stick well under the ratings and you will be fine 4 lights on a 15 amp circuit will get the job done just fine.
/ Fuse and wire size #35
Finally some usable advice
/ Fuse and wire size #36
I'm also running my 4 LEDs off a switch just fine. No relay. The wire really couldn't be any shorter it goes straight from the battery to the fuse block. A couple inches to the switch then straight along the frame yo the lights.
/ Fuse and wire size #37
Mace,
Ron
I think you should do a little more reviewing about the difference between constant impedance loads (such as lights and resistive heaters) and constant power loads (such as electric motors and regulated power supplies).
/ Fuse and wire size #38
Wow, R we beating this one to death !
The idea of using a relay is to keep the higher current flow outside of the cab or from under the dash panel, in turn reducing any chance of causing a fire.
I know you guys are up on all of the LED Lighting and the need or not for a relay but if your happy running 10 amps thru a switch, no matter what the rating of the switch is... Good luck.
Here is a schematics I have passed around, luck to Ya no matter how you do it !
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
2018 ALLMAND MP40-8BI-PORTABLE DIESEL GENERATOR (A59823)
2018 ALLMAND...
2017 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2017 Volvo VNL 760...
2021 John Deere 1025R (A60462)
2021 John Deere...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
