funnel for adding transmission fluid to a BX 2200
   / funnel for adding transmission fluid to a BX 2200 #1
JimC
Seguin, TX
Kubota BX2200
Here is what I rigged to add transmission fluid to a BX 2200,
I used a 1 1/2 " electrical elbow (I had it on hand)
I used a heat gun to insert a 1" coupler into the elbow
(if you use a 1" elbow forget about the heat gun and the coupler)
a piece of 1" pvc pipe, and a 1" threaded adapter
DO NOT USE GLUE.
screw the adapter into the filler hole on the BX 2200
assemble the pvc pipe, insert a large funnel into the elbow.
Add the UDT fluid. Much better than a flexable hose.
See photo.
jimc
   / funnel for adding transmission fluid to a BX 2200 #2
I like it. Thanks. Will build one for my 50 Hr service.
2014 Mazda Mazda3 Sedan (A48082)
2014 Mazda Mazda3...
Harrow Drag (A50860)
2014 Whisper watt Generator (A49461)
2014 Whisper watt...
Fuel Tank (A50860)
Fuel Tank (A50860)
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
Holiday Rambler Alumascape Travel Trailer (A48082)
Holiday Rambler...
