fullsize backhoe thumb on extendahoe
   / fullsize backhoe thumb on extendahoe #1
toolaholic
Won't the extensioh be permentaly extended some with the attachments welded to the stick? does this affect the strength in hard digging?
would a grapple on loader be a better option in this case? thank's in advanse tool
   / fullsize backhoe thumb on extendahoe #2
There is a different type of thumb for a extenda-hoe machine will hook on to the lower part of the arm and yes you will loose some power when you install a thumb more weight out there cuts bown on your lift.
   / fullsize backhoe thumb on extendahoe #3
would a grapple on loader be a better option in this case? thank's in advanse tool[/QUOTE
NO, Yes and Depends. Are you talking about a mechanical thumb or hydraulic? Either way it wont affect your range in the extendable dipper. It will affect your performance with all functions of your hoe. LIft capacity (craning) and boom and crowd force. Depending on your application a grapple may be a better alternative but still will have the same affects on performance as either a hyd. or mech. thumb.
Va Dealer
thank's guys. Like everything else in life, there's a trade off. Your input is helping! Machine is a 1990 mass. ferg. 50HX weighs 15,000 lbs approx
Thank's Greg, the smart thumb is the best mech. thumb out there .
they gave me a price of around $2900.
I am a gen. contr. that also does weld fab. I can build a similar one myself
little $$$. I'll use ar 400 steel for the tangs ,and mild steel for the rest.
   / fullsize backhoe thumb on extendahoe #7
If you build it, I'd sure love to see some pics of the process and how it turns out. I've been debating on the merrits of building one for around my place for the last few years and still haven't made up my mind.
Eddie
Eddie that,s a good idea. I'm on weld talk and shop floor talk.I have the
equeptment and ability. Time is the hard part! quess it's time to hit the shop at night tool
   / fullsize backhoe thumb on extendahoe #9
I've also been thinking about fabricating one, so I'd be very interested in seeing how yours comes together if you end up building one. I hear you on the night time shop work - seems like the only time I have to get my projects done!
This is how I plan to approach this.I will tac weld small bolts to the end of my original pins.I will then fab up all components out of plywood on the band saw. Then I'll drill some holes in the ply,slip them over the temp pins. I'll
also use some nuts and bolts as temp bushings in the ply. I have an extendahoe so it's a little tricky. all I need is the proper movement while the bucket gets tested in the air. when right, i start with the Iron!
Any suggestions welcome. In an earlier life I was a certified welder in the union. Have portable lincoln with ln-22 .068 fluxcore, millermatic 210
mig and buzz box. just bought hypertherm 600 [40 amp. plasma].
pleaze don't tell moma about all this! Tool
1827 (A51248)
1827 (A51248)
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
ALLISON TRANSMISSION (A53843)
ALLISON...
TMA (A49461)
TMA (A49461)
2021 Harley-Davidson FLHP Road King Motorcycle (A51694)
2021...
