Full synthetic
   / Full synthetic #1
greif
kaukauna,wi
Yanmar sx3100
Is it too early to switch to full synthetic motor oil at the 50 hr oil change?
Yanmar sx3100
   / Full synthetic #2
A lot of engines come from the factory with synthetic, so I don't see any problem.
I've heard this question asked before. Maybe older engines had issues with ring seating, etc??
   / Full synthetic #3
Yanmar sx3100
I guess you could but break-in may take forever.
Are they telling to do the first oil change at 50 hours? That is very early. Maybe don't use synthetic yet. It would not hurt you to go 500hr or to a year on conventional oil if you don't put on that many hours. That is what I did with my tractor and have had no issues. Best to ask your dealer their thoughts on it.
   / Full synthetic #4
At the 200 hour change I went to full synthetic and so far so good. I'm gonna change the filter at 300 hours and top off then at 400 hours I will change the oil and filter.
   / Full synthetic #5
Not to early IMO.
I went to synthetic at the first 50 hour change on my tractor. (its has 2000 hours now)
My zero turn called for the first oil change at 8 hours and I went to synthetic.
   / Full synthetic #6
not too early. Put it in at 50 if you want. I did. New cars and trucks all come with it right out of the factory.
   / Full synthetic #7
Just about everything I have gets either a full synthetic or synthetic blend at first oil change. I have never had any issues. Gassers, Diesels, lawn mowers, portable generators, gator, ... all of them.
   / Full synthetic #8
Unless your owners manual calls for a specific breaking oil, and specifies a breaking period, (which is rare today), you can switch anytime you like.
Check the spec's for your motor oil. Lubricity is basically the same now for both, mineral oil, and synthetic oil. That means the engine won't break any different, with either one. This is why engines now often come from the factory with synthetic oil in them.
If it was important for you to wait, you would not need to ask this question, your manual would specify that.
If you choose to believe incorrect, outdated thinking, which tells you otherwise, you can wait, and switch later. That won't matter either.
It's 2016, it's all just oil now. The only difference is, synthetic works better in extreme temperatures, and allows for longer drain intervals.
   / Full synthetic #9
True. For the GM crowd, dexos1 and dexos2 GM oil specs virtually demand a synthetic blend at a minimum. And they are factory filled with it.
   / Full synthetic #10
My 2014 e350 came syn...
The day I brought my new mtd home from tsc, I swapped it to syn.. That's been 3ys now?
2019 Allmand Night-Lite V-Series S/A 7kW Towable Light Tower (A52377)
2019 Allmand...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
1995 PETERBILT 377 TRI  AXLE DUMP TRUCK (A54607)
1995 PETERBILT 377...
2021 JOHN DEERE 624P WHEEL LOADER (A52705)
2021 JOHN DEERE...
