full or partial syncromesh?
   / full or partial syncromesh? #1
mathey
Platinum Member
MD
NH TC33D
Did the older model LB1914 (1996-1997) have a Partial Synchromesh with Mechanical Shuttle transmission as opposed to the newer models which have a Full Synchromesh with Mechanical Shuttle transmission?
What exactly is the difference?
   / full or partial syncromesh? #2
Can't answer the specific question on that model, but partial syncromesh applies to the top gears and is used to get up more speed while traveling. At lower speeds, you have to come to a complete stop to shift. If you find first too low for your needs,you have to stop and shift to second, then resume. Conversely, if second bogs down, you have to stop completely to shift to first, then go again. Not the best in marginal traction situations. While traveling if you find third to slow, you can shift to high without stopping. Full syncromesh allows shifting between all gears while traveling. Take note, I'm talking about transmission gears. Range gearing is usually never syncro. If you have 8 speeds - 4-speed, 2 ranges shifting between the speeds is either all or partial syncro, shifting between the ranges isn't. You always have to stop to shift between ranges.
Hope this helps
Pacesetter
   / full or partial syncromesh? #3
Pacesetter, I couldn't have said it better. /w3tcompact/icons/smile.gif/w3tcompact/icons/smile.gif
KO
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
2023 JOHN DEERE 30P TIER EXCAVATOR (A51242)
2023 JOHN DEERE...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
