full circle
   / full circle #1
dmltrac
In shopping for a tractor the first one I looked at was a mahindra 4110.
I then checked out NH, kubota, kioti and mf. Decided at first to buy a kioti, changed my mind to a kubota then back to kioti larger tractor then to kubota again.
When it came down to putting down the cash I decided the mahindra 4110 I looked at first (could have saved a lot of stress just buying it then!) was the best value. Should have it in a few days.
   / full circle #2
dmltrac
You made the right choice, after all we just found out that Mahindra is the 4th largest selling tractor /forums/images/graemlins/grin.gif
all kidding aside, you would not have known the quality of Mahindra if you did not do the shopping you did. Good Luck and keep active on T B N / Mahindra forums
Ron
   / full circle #3
dmltrac
i went thru almost the same thing except i started with a JD and checked out almost every tractor until i found the mahindra. from that point on it was between the john deere and the mahindra. after closely comparing,and trying them out it really wasn't much of a decision. i was getting a bigger,heavier,stronger tractor for several thousand less.
with a 3 yr warranty and better looking to boot! /forums/images/graemlins/grin.gif
Rudy
   / full circle #4
Congratulations!
I bought my 3510 after looking at the others, and after being in the equipment business most of my life decided it was the best value. I have over 100 hrs on it now and am more satisfied every time I use it! /forums/images/graemlins/cool.gif
Clark
   / full circle #5
Man, the same old story /forums/images/graemlins/shocked.gif
I came, I saw, I looked, I looked again, I bought red.
A lot of that going around these days /forums/images/graemlins/grin.gif
I think you will like your machine, I like mine. There are a few quirks with the Mahindra, but if you look at the other boards, the different colors all have their own set of problems and the Mahindra's seem pretty minor so far.
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
Detach Trailer (A50514)
Detach Trailer...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
