Oil & Fuel Fuel transfer pump
   / Fuel transfer pump #1
Bass
Kubota GL3710HST
Back problem keeps me from lifting 5 gal can to top of L3710 to pour fuel into tank. Any suggestions on fueling from a 5 gal can would be appreciated.
   / Fuel transfer pump #3
I have sinned.
I'm normally a stickler for safety and doing things right, but I am cheating on my fuel setup. I bought a transfer pump from Harbor Freight, and some fuel-rated hose, and I'm good to go. It's got a thermal overload that shuts off the pump after about 20 minutes. A half hour of cool-down, and it's ready to go again. I've been using it for about 5 months.
12 Volt Marine Utility Water Pump
   / Fuel transfer pump #4
The very reason I bought this 5 years ago. It is diesel rated. Just need to be mindful of keeping it clean. It requires 1.5" opening.
   / Fuel transfer pump #5
Bass
If you do a search, or look at the above replies, you'll see that some use anything from a 2 gallon garden watering can, some 2 1/2 gallon plastic used oil jugs, to 12 volt pumps (from $40 to $300). There are a lot of possibilities.
   / Fuel transfer pump #6
Lots of cheaper alternatives that may not be rated for flammable liquids.
I opted for the more expensive but surely safer steel (or you could get aluminum) 100 gallon tank with a 12 volt (also available in 110 volt) Filrite brand 15 GPM pump with 10 micron inline filter and an auto-shutoff nozzle attached with 25 feet of hose. I got the whole setup used for $350. I bolted some steel swivel caster wheels to the tanks mounting tabs (it is designed to be bolted down to a truck bed) so I can roll it around as needed. Even with 100 gallons of fuel, it can be rolled easily on my concrete shop floor.
I keep it inside away from direct sunlight which limits the condensation factor. It has been a possible lifesaver or at least a back saver for me. I just pull up my tractors or RTV to the shop door, remove the nozzle, turn on the pump and fuel up. Rather than try to hook up cables to a battery, I bought a small automotive battery, put on a battery minder and mounted it above the fuel tank on a shelf. It has been that way for over 5 years and still no issues with the battery.
I opted for the 12 volt pump rather than look for a 110 volt just for the option of having fuel available even if a power outage occurs.
Putting money into a large storage tank and a fairly expensive pump with battery might seem overkill, but just one slip while trying to stand on a tire or slippery tractor platform with a 5 gallon can of fuel could put you in an accident situation that may cost you many thousands of dollars plus the pain and suffering that goes with it.
   / Fuel transfer pump #8
Looks like a nice setup. Let us know how it works out.
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
Brush Cutter (A50322)
2012 Toyota Camry Sedan (A50324)
2012 Toyota Camry...
