Fuel Tanks
   / Fuel Tanks #1
eserdy
I'm currently looking to purchase a fuel storage tank that is 250 gallons above ground. The tank comes with a manual pump and has been used as a gasoline storage tank. I would like to use this tank as a diesel storage tank but am a little uncertain as to if this would work. If anyone has some incite it would greatly be appreciated.
   / Fuel Tanks #2
While the tank would certainly work to hold the diesel I would check the pump to see if it is compatable with diesel. If you use bio diesel there are more pump compatability issues.
   / Fuel Tanks #3
Should work just fine. I would check for rust inside but other than that it ought to work good.
   / Fuel Tanks #4
I would only add to make sure that the tank has been completely emptied. No residual fuel.
   / Fuel Tanks #5
I agree but I'd ditch the manual pump and replace it with an Elect 12 volt .
140 bucks over the life time of tractor ownership shouldn't break the bank for anybody.:)
   / Fuel Tanks #6
Speaking of fuel tanks.
Click link for nice larger photo.
http://i283.photobucket.com/albums/kk286/lb59/100_2340.jpg
   / Fuel Tanks
thank you for the input, should work just fine
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
John Deere 6120E (A50323)
John Deere 6120E...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
