npaden
Platinum Member
Well, I'm not sure what happened by my fuel tank is leaking on my Kubota L4200. I'm pretty sure it started on Saturday after mowing on some rough ground so maybe I stressed it or something.
I circled the area in red where it is leaking. It appears to be leaking from the inside of the hole where the bolt goes into the tank. The leak was fairly slow with a drip about every 2 seconds until I unscrewed that mounting bolt when I was working on removing the heat shield to see if I could find the leak and then it started leaking much faster and was running out of the hole where I removed the bolt. Probably 2 or 3 drips per second after removing the bolt.
Here's a picture from the parts diagram:
The fuel tank is a $500 part from Kubota so I'm wondering if there is a way to fix this without buying a new tank. Removing the tank looks like it is going to be a chore all by itself so I would love to be able to fix it with the tank still on the tractor but I doubt that will happen.
One thought that I had was to let it dry out (I drained the tank down past the leak after I found it) and then squirt some silicone in the hole and put some teflon tape on the mounting bolt and just put it back together and see what happens. That would be cheap and easy but not sure if it would have much chance of working or not, and not sure how long it would last if it did work.
The other thought would be to pull the tank and somewhere in the dark recesses of my mind I seem to remember hearing someone talk about getting their fuel tank "re-lined". Has anyone else heard of that?
Any other thoughts or suggestions?
Thanks in advance. Nathan
