Fuel Supply Problem
   / Fuel Supply Problem #1
KOKTAY
New Holland TC25
The problem with my TC25 started with it losing power while mowing. I couldn't keep the rpms up even at full throttle. I changed the fuel filter and bled the lines. This helped a little but not much.
I rebled the lines and got a little air out, but now I have lost fuel pressure.
Anyone have any suggestion?
   / Fuel Supply Problem #2
Something is clogged, a filter or perhaps a collapsed fuel line between the tank and pump. I had a similar problem with my Jinma 254. Two years of going nuts, than I found an unlisted filter sitting on top of the sediment bowl nipple inside the fuel tank. Never can tell what they may be doing at the factory. :mur:
Thanks for the help.
I found the problem. I managed to unplug the fuel solenoid while working with the fuel lines. Some days I am not as bright as others.
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
Park Dump Trailer (A52377)
Park Dump Trailer...
2014 KENWORTH T800 (A53843)
2014 KENWORTH T800...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53473)
2023 New Holland...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
