fuel starved?
   / fuel starved? #1
stormpetrel
Block Island R.I.
ym2210D
The latest issue I'm having is fuel starvation. The filter is brand new, the tank is well vented, no air leaks apparent. The tractor runs beautifully for a few minutes, then dies out. I'm not sure what it could be...something stuck in the line to the bowl? I'm gonna look at it in the morning. Any suggestions?
Oh....I have a new air filter. I'll try that.
   / fuel starved? #2
There have been people who had trouble with air leaks around the bowl itself causing those symptoms, as I recall.
I would start at the bleeder at the pump and see how much fuel comes out. If it only flows a little, work back to the next bleeder upstream and find the blockage.
   / fuel starved? #3
While you are at it. Replace the line from the tank to the bowl. I had no problems,but replaced all of my fuel lines
   / fuel starved? #4
I guess you read the 1510 thread right below this where he had trash in the tank. Is that possible?
   / fuel starved?
It is possible; the prior owner did not have a screen in the fuel tank. Hmmmmm.
   / fuel starved? #6
Screen dont really mean anything. I have one but take it out to fuelup, as it restricts the flow and causes little splashes from it. Im using a clean tank to pour from and its filtered at the pump anyhow so i dont worry much as there is a filter there in the system.
Curious, does the strainer need to be there to help vent the tank? Isnt there a little notch in it which is where the vent is drawn through. I know at least one person on here said they had a vaccume and it was cause by screwing the fuel cap to hard and squeezing the rubber gasket into this vented channel thus making it a ventless tank. I alway just snug it up and maybe a tiny bit more to keep it from loosening.
   / fuel starved?
Interesting you say that; the tank had no screen when I bought the tractor, and the tank got all scrunched w/vacuum!! It was explained to me that the screen also vented the tank.
I still haven't messed with the tractor, when I do, I'll watch the bowl for running dry. If it does, I'll know that the problem is in the hose or tank.
   / fuel starved?
I checked the hoses from tank to injector pump etc., and fired her up. Noticed air bubbles in the bowl. Shut her down. Tightened the bowl on good. Fired her up again. Runs fine. I still have to give her a good work out bush hogging or finish mowing to see if the problem is gone. But I think I didn't tighten the bowl down when I changed the filter. Operator error.:laughing::laughing::laughing:
Ahhhhhhh, well.
   / fuel starved? #10
Good news! That's a relief.
2009 Dodge Grand Caravan Passenger Van (A53117)
2009 Dodge Grand...
INMY Manual Landing Gear (A51692)
INMY Manual...
2017 Ram ProMaster City Cargo Van (A51692)
2017 Ram ProMaster...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2016 RAM 3500 HD SERVICE BODY TRUCK (A53426)
2016 RAM 3500 HD...
