Fuel shut off valve
   / Fuel shut off valve #1
MuncyBob
Platinum Member
N Central PA
PT 422
OK, I finally got around to buying one of these. Does it matter if the shut off is installed before or after the fuel pump?
   / Fuel shut off valve #3
for me, clearly before the fuel pump, or before fuel filter, if there is no shutoff on the fuel filter...b ut you gotta put it where it will fit.
   / Fuel shut off valve #4
Twice my float valve failed and I ended up with a crankcase full of gasoline. No more. I installed an inline shut off valve about four inches below the tank where is is easy to reach when the engine is hot.
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2021 FREIGHTLINER...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
