Fuel shut off solenoid. Did not work
   / Fuel shut off solenoid. Did not work #1
Mobass
Bronze Member
Lebanon, MO
Mahindra 8560
Replaced the fuel shut off solenoid. But still having intermittent shut off. Will run for 15 min to a couple hours. Let tractor sit a few hours and it will start back up. Getting 2.1 volts at the wire going to the shut off. I am stumped and getting peeved at this situation, Plus Mahindra doesn't warranty the fuel system after 2 years. Any suggestions??
   / Fuel shut off solenoid. Did not work #2
Full disclosure here, I have no actual knowledge of Mahindra fuel shut off's, I have a very good working knowledge of my Kioti fuel shut off system..
That said, do you have the schematic? Does the fuel shut off solenoid have a relay that provides power for the solenoid, is there two coils to the fuel shut solenoid, a pull coil and a hold coil? 2.1 volts sounds like a problem. Burned contacts on the relay?. Step one to fixing any electrical problem is understanding how the circuit works. By analysis of the schematic, you form a hypothesis of the possible problem then make diagnostic measurements, like you have done, and then try to "break the circuit in half" and determine if the problem lies in one direction or the problem lies in the other direction.
If you have no schematic, getting one would be the first operation to complete. See if there is a theory of operation of the circuit listed in the troubleshooting section. Can you post the schematic here so I could help analyze it?
I will try to find a schematic for you.
   / Fuel shut off solenoid. Did not work #4
Just my 2 cents and it may only be worth that.
What makes you think it is the fuel shutoff solenoid? Solenoid could be losing power, some blockage of fuel some place, bad fuel pump/transfer pump, if you have one.
   / Fuel shut off solenoid. Did not work #5
Well my first impression was that the tractor will not shut when he turns off the key, but the tractor continues to run for 15 minutes up to 2 hours after the key is turned off. Perhaps I misunderstood the problem?
   / Fuel shut off solenoid. Did not work #6
Perhaps a better title to your thread would be "my tractor runs for an intermittent period of time and then shuts down by itself?"
Hope this works
   / Fuel shut off solenoid. Did not work #8
Depending on which way the solenoid works, could the OP remove the solenoid and run the tractor to see if it still quits? That way he would be bypassing the whole shut off circuit for testing purposes. (or, does it have to be installed to run?)
   / Fuel shut off solenoid. Did not work #9
I'm at a client meeting now, and the attachment only came up with a mahindra logo. But if you come up with anything else I'll be happy to help you with this late afternoon or early evening
   / Fuel shut off solenoid. Did not work #10
You can jumper 12volts straight to the solenoid to get it back in if it stops out in the field. The solenoid requires 12volts to open the fuel flow to the injection pump. You should have a print in the back of your owners manual. You have to find out why you are only getting a couple volts to the solenoid. If you are not 'up' on electrical trouble shooting, stop and find a friend/neighbor to help you out. Most problems are pretty simple. Not trying to 'slight' your problem... but hang in there.... :)
   / Fuel shut off solenoid. Did not work #11
Jerry do you know if there are two coils on the solenoid like my Kioti has? The first coil take 28 amps to pull back the armature of the solenoid, and a timer circuit applys this 12 volt power thru a 30 amp relay for 1 second, then the second coil requires less than 1 amp of current to "hold" the armature back against the spring pressure once the armature is pulled back by the large surge current. This small holding current is supply by the "ON" key buss voltage.. So when you turn off the key this small 12 volt supply line to the "hold" coil goes away and the solenoid snaps shut by the spring pressure. Do you know if the Mahindra works the same way?
   / Fuel shut off solenoid. Did not work #12
Don't know about his Mahindra... but my 5035 is set up to apply 12v to the solenoid thru a 5 amp fuse whenever the key is in the RUN postion. This wire also supplies 12v to the KSB timer and also the KSB solenoid for the first 20min plus or minus. He will have to check his print. But I'd bet money [ this is just an old saying, doesn't mean real money ] his Mahindra is made in India and has a simular Bosch injection pump as mine... [ I know, lot of 'assumating' here on my part.... ]
   / Fuel shut off solenoid. Did not work #13
Yep, so many different ways by so many manufactures to accomplish the same goal. Turn the dang tractor off with the key switch. Remember when we all just had a manual pull knob? Worked OK too. Unless you were too "stoopid":) to push it back in when you tried to start it next time.. But I wouldn't know about that.!:eek:
   / Fuel shut off solenoid. Did not work #14
Yup, I'd rather have the manual shut-off, too... Speaking of stupid, I was running a J.D. excavator once. Had a **** of a time getting it to start jumping it with one of my old tractors. Then, couldn't figure how to get the durn thing to shut off. Finally got hold of the owner and he told me that you had to move the throttle all the way past FAST. Weird...... :)
Correct. Sorry for the misunderstanding.
   / Fuel shut off solenoid. Did not work #16
If you have not already done it. I would suggest you contact your dealer and ask that they e-mail you a picture and maybe an explanation of the starting system. Once you have this and if you would post it, I think we can help you figure out what is happening.
As already pointed out there is a few different ways that the fuel solenoid works.
This morning we checked the volts and it read 11.5. Started right up ran around 20 min then died. Ran the wire backed checked the 15 amp fuse it was good all that is left is the shut off relay. We by passed the relay and it started but did not run like it normally does. Make me think that this is the problem. Called dealer told him what it has been doing and he thinks this is also the problem. But then again they charged me $350 for thinking they fixed it the last time.
   / Fuel shut off solenoid. Did not work #18
I am with him on his suggestion,,,,, I had an electrical Gremlin just like you do. One of the first things I did was purchase a repair manual for my tractor and in one evening I was able to see how to troubleshoot the problem area and identify all aspects of electrical operation. For less than 100 bucks you will have the same resources that your dealer has- and have it at your fingertips in the comfort of your home.
Just letting you know that that book is worth every penny if you have the drive to make repairs on your own. However, doing service/diagnostics/repairs is not everyone's cup of tea. Some just farm out the work for a small fee....;)
   / Fuel shut off solenoid. Did not work #19
When it quits running, pull the fuel line off AT THE TANK, and see if you have fuel flowing.
My Yanmar did this EXACT same thing....intermittently died...would start up and run anywhere from 5 minutes to many days with no problem.....then die again. Drove me AND the dealer nuts.
Dealer replaced the fuel solenoid twice before they finally figured out it was plastic shavings (from drilling out the tank for the fuel line fitting) along with a couple bugs...this 'marble' would float around in the tank until it centered over the fuel outlet, then shut off the flow.
Stop checking electric and check for FUEL.
Kubota L4701 (A53317)
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
43023 (A59228)
43023 (A59228)
1608 (A57192)
1608 (A57192)
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
