Fuel question
   / Fuel question #1
bobcat7532010
Started up the 753 and ran it for awhile no problem what so ever. ( ran it for about 1 hour) Then it just quit just died. Now I did add fuel So my first thought was it was bad or it was gas but it smelled like diesel it wants to start but no go. SO now can I suck out the 5 gallons that I added and put in fresh fuel and go or is there something else I should do??
   / Fuel question #2
I't might be simplier to change the fuel filter and add a gas rejuvinator. You also might have ended up with some water in the tank. In that case disconnect the fuel line before the fuel pump and drain to a second gas can.
Hope this helps.
   / Fuel question
Fixed ==== the fuel line in the tank dropped off ---all is better now...
UNUSED CFG INDUSTRIAL MX50R EXCAVATOR (A51247)
UNUSED CFG...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53472)
2015 RAM 5500...
1838 (A51248)
1838 (A51248)
40' CONTAINER (A51248)
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
