Fuel pump problems, ingersol 4016
   / Fuel pump problems, ingersol 4016 #1
Dave Joaquin
Londonderry, NH
Ingersol 4016
Folks, my I4016 tractor with a twin Vanguard engine has a fuel pump problem. I believe it works on a vacuum system, every time I use it in the summer It stalls and I figured out it wasn't getting gas. To get it running again I have to blow the crap out of the fuel pump and sometimes I have to take it apart and blow it clean. Most of the time that works, but now It's beginning to bug me. I also blow out the little brass screen on the bottom side, I assume this is the air intake to create the vacuum. Can someone tell me why is this happening all of a sudden? Also, can this be replaced with an electric pump? This only happens in the summer, never in the winter when I'm snow blowing.
   / Fuel pump problems, ingersol 4016 #2
Your local NAPA dealer sells a 12 volt pump that puts out about 2 PSI. You don't want much more pressure than that or else you will have a flooding problem. Wire it to your keyswitch on the terminal that gets LIVE when the key is in the ON position. Install an in-line fuel filter just before that new pump.
Hydriv, Thank you. I will buy one and try it. There's already a fuel filter there, I changed that a couple of weeks ago.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55218)
2016 RAM 5500...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2021 CATERPILLAR 279D3 SKID STEER (A52705)
2021 CATERPILLAR...
Pallet of Miscellaneous Mini Excavator Attachments (A52377)
Pallet of...
2005 JLG 660SJ TELESCOPIC MANLIFT (A52705)
2005 JLG 660SJ...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
