fuel problem in 1993 440-b. won't stay running.
   / fuel problem in 1993 440-b. won't stay running. #1
walter rix
warwick rhode island
440-b bobcat
I'm having a problem keeping the bobcat skid steer running. Was intermitant, now just won't run. Any suggestions?
   / fuel problem in 1993 440-b. won't stay running. #2
Welcome to TractorByNet!
I moved your thread to the Bobcat Construction Equipment forum. :)
   / fuel problem in 1993 440-b. won't stay running. #3
HI, Not sure if you've received any replies yet. I just fixed my 742 and I'm guessing your 440B might have a similar system. My problem was a split in the pickup tube in the fuel tank. The machine would stop working unless I filled it up with gas. The old pickup tube in the tank had a split in the tube from the tank fitting to about half way down. The diesel and gas 740 series use the same fuel system and can have the same problem. THe only difference with the two fuel tanks is the gas does not have a fuel return line as the diesel would.
Hope that helps!
Guard Rail Joints (A51692)
Guard Rail Joints...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
(APPROX 50) 2" X 2" X 97" TUBING (A51247)
(APPROX 50) 2" X...
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
