Oil & Fuel Fuel oops!
   / Fuel oops! #1
Anonymous Poster
Epic Contributor
Ok here's the deal guys. I sent the wife out to get some fuel for the house.We've been using dyed diesle. I thought I'd scam a little for the BX. Well it's a good thing I owned up to the wife. It turn out she got dyed kero instead this time because it was cheaper. I only put in about 1 &1/2 gal, and I'm only up to a half a tank. Should I just top her off with the right stuff or should I drain out the tank./w3tcompact/icons/hmm.gif
   / Fuel oops! #2
For winter use, many people use a 50% blend of regular diesel and kerosene. Fill the rest of the tank up with diesel and you'll be fine. No need to drain the tank.
   / Fuel oops! #3
<font color=blue>...Should I just top her off ...</font color=blue>
As Mike already said... I'm running a blend of diesel and kerosene... as of this week 50/50... and change according to weather... colder will get higher % of kerosene and vice versa... warmer less... until springtime comes back... /w3tcompact/icons/smile.gif (I have never used any diesel additive... but I use fuel fast enough... so it's never stale nor sitting for months to gain any moisture... otherwise I would)
So... being in the NE US (PA)... you won't even miss a beat this winter with your "winter blend" you inadvertently stumbled upon... /w3tcompact/icons/wink.gif
   / Fuel oops!
Well, I guess I feel Better now. It's just a lot of money to be messing around with ya know!/w3tcompact/icons/smile.gif
   / Fuel oops!
Where in NE PA are you? (Just curious as I grew up there)
   / Fuel oops! #6
Only problem w/ kerosene is it
has less BTU or makes less power.
OTR semis get less MPG because of
this.
So if u notice a little less power straight
diesel fuel will restore it.
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
Portable Calf Creep Feeder (A50515)
Portable Calf...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52128)
Michelin CARGOXBIB...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
CATERPILLAR 303E CR EXCAVATOR (A51242)
CATERPILLAR 303E...
MAH QUICK ATTACH MAST W/ 48" FORKS (A51242)
MAH QUICK ATTACH...
