Fuel oil tank clean out, how?
   / Fuel oil tank clean out, how? #1
Slippy
Veteran Member
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Found an old fuel oil tank to convert for diesel fuel. Anyone know the best way to clean it out? Thought about sticking my power washer wand in it.
   / Fuel oil tank clean out, how? #2
I would recommend a good flush out with a de greaser first, even leaving it in the tank to soak in for a couple of days.
secure a small brush on to a rod so you can clean the inside as much as possible.
Using a steam cleaner is a good idea for old tanks.
If you think that there is rust flaking off inside then check with your local trail bike shop, there has been a product out for a while that seals the inside of rusty tanks
It may also be a good idea to use a sedamant bowl on the outlet of the tank to catch any initial gunk before it gets to the filters.
Good Luck
Roscoe
Good ideas. THanks.
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
2012 John Deere Z925A 60in Zero Turn Commercial Mower (A52377)
2012 John Deere...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
