Fuel oil coming out of starter drain hose on d950
   / Fuel oil coming out of starter drain hose on d950 #1
asdfgh
WNY
CASE 275
Hello all. Any help would be greatly appreciated. I am getting fuel oil out the starter weep hole. I have changed gaskets on the fuel pump and hydraulic pump on the engine. I did this because I believed at first either was getting in the engine oil. What is being drained out the starter feels like fuel oil (I do not have dyed fuel oil). It is also a watery consistency, not extremely oily. It only leaks out while the engine is running. I have pulled the starter and the flywheel is coated with oil. Am I right, that there is no other way for fuel oil to get into the bell housing.
   / Fuel oil coming out of starter drain hose on d950 #2
"I have pulled the starter and the flywheel is coated with oil."
What kind of oil? Could it be the rear main seal leaky engine oil?
Peterbilt (A51692)
Peterbilt (A51692)
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
