Fuel line size
   / Fuel line size #1
paulcho
ringtown pa.
john deere gx345 Wheel Horse 518H
What size fuel line is used on a John Deere model GX345
   / Fuel line size #2
I find 5/16 to 20 hp and ⅜ over that on my small engines from different mfgrs, 15 to 26 hp air cooled singles and V twins. The fuel filters used in such machines are usually dual tipped inlets and outlets to fit both size fuel lines.
   / Fuel line size #3
It's 1/4"
   / Fuel line size #4
This one application where even 'bigger is better' (within reason).
e.g. for 1/4" --5/16 or even 3/8" would not hurt, space permitting.
   / Fuel line size #5
If you consider the line not being able to seal at the pump and pick up etc. being a good thing, then I say go for it. There is absolutely nothing to accomplish with a larger ID fuel line on this rather than for those that want a little sport in their life by creating a fuel delivery issue or a fire... Top fuel GX345 maybe ;)
   / Fuel line size
Thank You all, I used the 1/4 inch and that worked just fine. The reason I changed the fuel line and filter the engine was surging, I had this same problem in June 1917 problem was bolts on carburetor and intake manifold were loose, Now this time I removed the top of carburetor and blew the small inlets out with the air hose, there is a brass tube with very small pin holes in it they were blocked, My tractor is a Wheel Horse model 518-H engine Onan P218
2007 Case CX160B Excavator (A42021)
2007 Case CX160B...
2015 INTERNATIONAL PROSTAR+ (A45046)
2015 INTERNATIONAL...
Pallet of John Deere Tractor Weights (A40783)
Pallet of John...
John Deere 4020 Tractor (A40783)
John Deere 4020...
2011 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A37757)
2011 FREIGHTLINER...
2015 MACK CXU613 (A45046)
2015 MACK CXU613...
