fuel line inside dia.
   / fuel line inside dia. #1
rangerrick180
griffin ga.
ym 180
hi folks
just wandering if anybody knows inside dia. of rubber fuel lines on a ym 180?
also my tractor has a loud whinging noise until it gets warmed up a little.
not sure where its coming from. any ideas are appreciated.
   / fuel line inside dia. #2
No warranty but I think it might be 7mm, I believe quite a few have used 1/4".
Does your whinging? noise change when you activate the hydraulics? That is my first guess.
   / fuel line inside dia. #3
Yea I think it could be the hydraulics as the fluid is thick. Is it worse when it's cold like cold outside.
   / fuel line inside dia. #4
Sounds like hydraulics. Just let her idle 'till it warms up a bit or change to a lighter oil...............Mike
   / fuel line inside dia. #5
is either 6 or 7mm.
Its not the end of the world if u use "standard" size line.. just MAKE SURE its sealed properly.
   / fuel line inside dia. #7
I use SAE size. And from what i remember it was 1/4 . That spring sheath, if yours still has it, would not fit over it, or at least i dont think it did as i didnt put it back on. Just tighten your hose clamps up and it will be good, there is not much pressure on that line, just what the gravity from the fuel makes. Its not optimal but it works. Mine has been this way for i think 2 years and not a drip.
   / fuel line inside dia. #8
I have used 1/4 SAE fuel line on both my tractors with no problems, and use tiny hose clamps on them too. As for the whinging noise, I agree it sounds like the hydraulics, either thick oil due to being cold outside, or maybe your hydraulic filter is getting plugged up too. If you don't know how old that fluid is, it wouldn't be a bad idea to see if you can get a small sample out and see how clear it looks and consider doing a fluid change and clean your filter.
   / fuel line inside dia. #9
Whining Sounds Hyd.. I'd drain it and pull and check the filter screen and see if it's clean. If it's dirty clean it and replace the fluid. Use a clean bucket to drain the fluid into and if it's clean and the filter was clean pour it back in and use it. I have a feeling it's going to be milky and the screens dirty. Esp. the last 1/2 gallon or so of fluid.
PT Canal Pump (A50121)
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A50322)
2025 GIYI GY-ZWB...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
JLG 1255 Telehandler (A52748)
JLG 1255...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52576)
2023 EAST TEXAS...
2020 GMC 2500 HD (A50120)
2020 GMC 2500 HD...
