Oil & Fuel Fuel leak on a 7305
   / Fuel leak on a 7305 #1
brantley
Bronze Member
Oklahoma City
Cub Cadet 7305
Just discovered a fuel leak on my 7305. It is up near the fuel injector pump by the intake manifold. From the look of it, I think engine vibration caused the line to rub against something until the line wore through. I have had the tractor almost 5 years and has about 200 hours on it.
Has anyone else run into this problem with any of the 73xx or 72xx series of tractors?
When I replace the line I plan on adding some extra protection to the line in that area to make sure that does not happen again.
   / Fuel leak on a 7305 #2
Sorry to hear that. I had almost 300 hours on my 7260 before I sold it with nary a problem. Try getting some wire loom from an auto parts store and wrap it around your new line. /forums/images/graemlins/wink.gif
   / Fuel leak on a 7305 #3
This is almost funny. I read this post a couple days ago, we got a snowstorm and I had to let Lucy out to play. What do I find on the new-fallen snow but pink off-road diesel color. Fuel line has a pin hole just aft of the oil filter from rubbing on the frame. FYI, it looks like if the fuel line were routed around behind the oil filter this wouldn't have happened. Also raises a question: Will a pinhole in the fuel line allow air into the system and rob the engine of power and possibly cause any damage??? Should I trade her in on a Mahindra 3015 as soon as possible? Just joking.
   / Fuel leak on a 7305 #4
Lucy's dad... no need to worry about the pinhole leak. The line pressure is more than the air pressure... worst case is leaking a little fuel. It's not going to suck air. Using some loom is a good idea... but I would also use some tie wraps to keep it away from anything that could harm it. With a little loom and some tie wraps you should be trouble free for a long time..... at least for that problem!!
You guys make me jealous! I want a CC!!
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
2000 Ford F-650 TMA Attenuator Truck (A50323)
2000 Ford F-650...
2005 JOHN DEERE 5205 TRACTOR (A51222)
2005 JOHN DEERE...
